3560 source/destination routing
Answered Question
Apr 28th, 2008
Trying to set up a test of a new WAN MPLS line hooked directly into the switch. i need to be able to specificy if you are coming from this VLAN(or IP range) and you are going to this IP range then you use this IP as the next hop. is this possible with this cisco switch? does that require PBR?
Correct Answer by Edison Ortiz about 9 years 3 months ago
Since you are planning to implement MPLS, you can have a routing table behavior for a specific VRF different than other VRF.
As VRF I'm referring the IP range you want the source/destination routing to be changed.
If you want to change just a subset of an IP range within a VRF, then you will need something like a PBR which deals with source-based routing behavior.
HTH,
__
Edison.
Overall Rating: 4 (1 ratings)
Correct Answer
Edison Ortiz Mon, 04/28/2008 - 14:08
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
