1841 - lost admin password/Can't get into
Answered Question
Apr 28th, 2008
I had lost the admin password on the 1841 I have, I changed the confreg register through logging in to the RMMON mode and now I can not get into it at all I tried several combination of hyper terminal and changing the flash card. All I get is %$$##$!#!#^%&& kind signs on hyper terminal. Please help.
Correct Answer by Sushil Kumar Katre about 8 years 10 months ago
Overall Rating: 4 (3 ratings)
Goutam Sanyal Mon, 04/28/2008 - 21:14
Hi, Check you consol port, make sure its working. Thanks Goutam. Pls rate if it helps you!!!
thaman303 Tue, 04/29/2008 - 05:14
Thanks, How can I check the console port of this router ? Its brand new though and on Baud rate 0f 9600 I can get into the other new router.
Rds
Sushil Kumar Katre Wed, 04/30/2008 - 11:28
The only option left with you is to try each and every baud rae setting available on the hyperterminal.
One of the baud rates would work. Then you can change the configuration register to default.
-> Sushil
thaman303 Wed, 04/30/2008 - 13:37
Thanks much Shushil, it worked.
Do you have a lost password recovery solution ?
Rds
