Does arp cache clear when i/f unplugged
Apr 28th, 2008
Does IOS automatically clear the arp cache, fast-switching cache and route cache for all IP addresses in a particular subnet if the router interface on that subnet is unplugged, or do I need to do,
clear arp interface <type> <number>
and
clear arp-cache
as is shown at,
http://www.cisco.com/en/US/docs/ios/12_4/ip_addr/configuration/guide/ipb_arp_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1096656
Thanks, MH
Overall Rating: 5 (2 ratings)
Richard Burts Tue, 04/29/2008 - 04:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
MH
If you unplug the router interface and if the router interface then goes to line protocol down, then the ARP cache entries associated with that interface should be cleared.
Rick
