guruprasadr Tue, 04/29/2008 - 03:42
  • Gold, 750 points or more
HI, [Pls Rate if HELPS]
Script provided on how to perform a periodic back up of a file in router's flash to an FTP server:
event manager applet backup-crl
event timer watchdog time 86400 maxrun 4294967295
action 1.0 cli command "enable"
action 2.0 cli command "copy flash:/iosca.crl ftp://username:passwd@a.b.c.d/" pattern "a.b.c.d"
action 3.0 cli command "a.b.c.d" pattern "iosca.crl"
action 4.0 cli command "iosca.crl"
action 5.0 syslog msg "FTP backup successful"
Refer Link below for more such EEM Scripts Posted:
http://forums.cisco.com/eforum/servlet/EEM?page=main
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
mpozorski Tue, 04/29/2008 - 08:28
I don't know if it's the best way, but I have ours setup with a simple expect script. The script is setup to run as a job on the server every night at 1:00am. The script basically telnets to the switches and routers throughout the network and copies the configuration via tftp to a server and the tftp root directory on that server is setup as a website that can be accessed via our intranet from our admin network. Here is a sample of the expect script I'm using for our gear;
#!/usr/bin/expect
# ACCESSW01
# Backup script for ACCESSW01
set timeout 15
set name "username"
set pass "password-for-user"
spawn telnet ACCESSW01
expect "sername:"
send "$name\r"
expect "assword:"
send "$pass\r"
expect "HQ-ACCESSW01#"
send "copy start tftp\r"
expect "ddress or name of remote host []?"
send "XXX.XXX.XXX.XXX\r"
expect "?"
send "\r"
send "exit\r"
expect eof
It is a rather simple approach although probably not best practice as the username and password are stored in plain text on a server. For a little added security I setup the user on our ACS server to only be able to run the command listed (copy start tftp) so that if the account were compromised the only command they could run is that. I have access-lists in place that denies tftp traffic to the outside so theoretically they could copy the configuration to an internal host which so far has not been an issue for us. Like I said before this is probably not the best solution but it works.
