VG200 Support on UCM 6.1
Apr 28th, 2008
Has anyone used VG200 with UCM 6.1 and can confirm if its supported.
I have seen the Admin Guide for UCM 6.1, which states the step to add MGCP gateways and mentions "From the Gateway Type drop-down list box, choose one of the following MGCP gateways:
•Cisco VG200"
Can someone please confirm this.
-> Sushil
Overall Rating: 5 (1 ratings)
Jaime Valencia Tue, 04/29/2008 - 07:50
Hi Sushil
I'm looking at my CUCM 6.1.1 server from the lab and when i click on add for GWs i get:
Cisco VG200
Cisco VG248 Gateway
If i choose VG200 i automatically get the config using MGCP
if this helps, please rate
Sushil Kumar Katre Tue, 04/29/2008 - 07:57
Hi Javalenc,
Thanks for the information. This is what I found in the admin guide.
Hopefully it should be supported.
Just wanted to cross verify if someone is already deployed this.
-> Sushil
