mahmoodmkl Mon, 04/28/2008 - 23:41
It depends upon the model of the switch u r using.
Mahmood
Sushil Kumar Katre Tue, 04/29/2008 - 01:58
Use the following link -
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800951ac.shtml#resource_error
Go to the configuration section of the switches provided under "Cisco IOS Software STP Restrictions" section in the table.
The configuration guide states the limitation.
If you are finding it hard to get the info, let me know the switch model you are using..
-> Sushil
