Switch issue
Apr 29th, 2008
I have a 4510R-E switch operating as Core. I have 3 4507R-E & 2 4506 switches operating as access switches. the 4507R-E switches are new switches which is recently got to network.the core switch is in server mode & the remaining switches are in client mode. However, only the switches of 4506 series are operating porperly with all the L2 VLANS refelcting immediately. However teh L2 vlans are not advertised to the switches of 4507R-E series & no L2 VLANs present. I have to move these switches to transparent mode, create VLANs and then move it back to client mode. Can any one one let me know, where the problem lies?
gojericho0 Tue, 04/29/2008 - 04:08
For the switch that is not replicating properly can you output the following:
show cdp neighbor
sh int trunk
sh vtp status
Also the the vtp status display, does the domain name (case sensitive) and md5 hash match the cores display in sh vtp status?
Istvan_Rabai Thu, 05/01/2008 - 18:52
Hi Deepa,
Please make sure the new 4507R-E switches have the same vtp domain and vtp password configured. You can do this with the "show vtp status" command.
Also check, if the trunks between the 4507RE and 4510R-E switches have come up as trunks.
VTP advertisements propagate on trunks only.
You can check this using the "show interfaces trunk" command.
Cheers:
Istvan
deepa.muralidharan Mon, 05/05/2008 - 21:53
Thanks! I finally found the root cause. VTP password was configured on all the 4507R-E switches but was not configured on the 4510R-E switch. Because of which VTP advertisements were not shared between the switches. I verified this with the revision number on the switches. On all the 4507R-E switches, the revision number was constantly "0" with the other switches having tallying revision numbers. I configured the VTP password on the switch & everything is working fine.
Istvan_Rabai Tue, 05/06/2008 - 11:19
You're welcome Deepa!
Please rate my post if it was helpful.
Thank you:
Istvan
