IPPhone 7911 language
Apr 29th, 2008
Hi all,
i have a CCM 4.1(3)sr5d.
and i have 7911, 7912, 7940,7960,7970 IPphones.
all the IP phone are in frensh language except the 7911.
hoever i specify french language in config, it's always in english.
how can i change the 7911 ipphone to start with french language.
datamex Tue, 08/12/2008 - 11:52
Hey,
Last week i found the same problem. but i updated my language package to the latest version. rebooted the CM4.1(3)SR3a and after the reboot i checked. the phones configuration.
It says than you current language settings.
The end user confirmed it was in Dutch as it should be.
Maybe you solved it already otherwise i hope you think this helps to solve your problem :)
