CUPS Trousblshooter "Unable to connect to CallManager publisher node"
Answered Question
Apr 29th, 2008
Dear Sirs,
After installing my CUPS and doing basic configuration, still iam i got this problem which states "Unable to connect to CallManager publisher node with address 10.21.0.3 " from CUPS troubleshooter, it suggests a solution for me to " Please verify the publisher address, AXL user-id, and AXL password on the CUPS AXL Settings page " to fix the problem, and i did that solution on both way:
1) I used the CCAdministrator account as AXL user-id on both sides (CCM & CUPS), but still the problem unresloved.
2) I created new application user and assigned Standered AXL API role to it on both sides, but my still problem didnt reslove.
Kindly advice me to have clear solution.
Note: Trobleshooter Snapshot is attached.
Correct Answer by Tommer Catlin about 9 years 2 months ago
Check your AXL password. Make sure it does not have any special characters in it. For some some reason AXL does not like symbols or special characters in the password. So it make simple, then test.
Overall Rating: 5 (1 ratings)
Correct Answer
Tommer Catlin Tue, 04/29/2008 - 07:09
  • Green, 3000 points or more
wmulla465 Tue, 04/29/2008 - 21:33
Thanks a lot Mr. tcatlinins,
I did what u mentioned above and it working fine now as shown in the attachment.
Please keep in touch for further support
Thanks & Best Regards,
