AP 1200 print issue
Apr 29th, 2008
We have a Cisco AP 1200 that has been configured with the standard config. Users have no issues authenticating and associating with the AP, however, they can't seem to print from it. They can print with a wired connection and I can ping the printer from the AP. Can you anyone pls help? The
Thanks.
Alex Pfeil Fri, 05/02/2008 - 07:55
If you can't ping the printer from the wireless station, then it is a vlan issue. You might have your backbone network setup so you can ping everything on your network, i.e. you can ping the printer from the access point. However, a ping from the computer would fail. Check your vlan setup or let me know if you can ping from the wireless clients.
Alex
a.mir Mon, 05/12/2008 - 06:06
Hi, Thanks for the response. I can ping the printer both from ap station and from the wireless user. It just doesnt print. looks like the connectivity is there with wireless but it doesnt print. But the printer works with the wired connection.
Alex Pfeil Mon, 05/12/2008 - 06:28
I don't think this is a wireless issue,
try using different drivers and troubleshooting the printer setup. Check spooling.
I'm throwing out ideas.
Alex
