Very anomolous traceroute
Apr 29th, 2008
I am trace-routing from a cisco switch to a cisco router 4 or 5 hops away. I can ping the remote device ok. But the trace-route shows the SAME IP address repeatedly for each sequential hop - ie the originating switch only (the ip of the outbound interface) and does not display each downstream hop address. I have to break out of the trace route routine after a while as it times-out (after repeating the same source address over and over)- Anybody seen this before? Thanks in advance [email protected]
