Applying QoS on GRE tunnel interface
Apr 29th, 2008
Please I configured a Class based weighted fair queueing on a cisco 3845 router with the following image c3845-advipservicesk9-mz.124-3g.bin. I applied it on a tunnel interface and it returned with the following error. (Class Based Weighted Fair Queueing not supported on interface Tunnel5). Pease is it possible applying QoS on GRE tunnel interfaces and how?
Overall Rating: 4 (1 ratings)
guruprasadr Tue, 04/29/2008 - 06:26
HI, [Pls Rate if HELPS]
Eg: I have provided for a 128K Link Sample.
Create a "Parent Policy Map" and apply the "Child Policy Map" as a command under parent policy since admission control for the child class is done based on the shaping rate for the parent class.
policy-map Customer-Parent-128
class class-default
shape average 128000
service-policy CHILD-Priority-128
interface Tunnel 5
service-policy output Customer-Parent-128
Refer Link below for details:
FYI, The tunnel interfaces also support class-based policing, but they donot support CAR.
Hope I am Informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
bnnatuanya Tue, 04/29/2008 - 23:14
Great. really very informative, I appreciate this so much. thanks
