How to clear unwanted vty line in config
Apr 29th, 2008
For some reason, one of my customers switches has an awkward vty line configuration that I have not before seen.
Here is the config on the switch:
line con 0
line vty 0 3
transport input none
line vty 4
password xxx
transport input ssh
line vty 5 15
password xxx
transport input ssh
I am not certain why the "line vty 0 3" is configured. I just want to delete it.
I have been entering the following and getting the following error:
bhisc3# conf t
Enter configuration commands, one per line. End with CNTL/Z.
bhisc3(config)#no line vty 0 3
% Can't delete last 16 VTY lines
bhisc3(config)#
Can anyone advise me of how to configure this to remove the line vty 0 3 from the config?? It should be part of the inherent line vty 0 4 group anyhow...
Overall Rating: 5 (1 ratings)
Kevin Dorrell Tue, 04/29/2008 - 07:31
  • Green, 3000 points or more
The only way you will get rid of it is to make sure that VTY 0 to 4 have identical configs. At the moment, they are different. Try:
</p><p>line vty 0 4</p><p> password xxx </p><p> transport input ssh </p><p>
Kevin Dorrell
Luxembourg
