can't login to Personal Communicator - freezes
Apr 29th, 2008
Trying to install on XP laptop. It installs ok but after launches it only allows me to enter a few keys in username/password box then freezes. Tried uninstall/reinstall, tried .exe/.msi files.
Does it matter that IP Communicator also on laptop?
gogasca Tue, 04/29/2008 - 19:53
  • Green, 3000 points or more
It should work fine, which version you are using for CUPC?
It was working fine at some point?
