04-29-2008 07:42 AM - edited 03-03-2019 09:44 PM
Greetings,
Given an all-cisco Layer3 MPLS VPN (RFC 2547bis) network what are the maximum MPLS label stack depth and Path MTU required?
CE1--a--PE1--b--P1--c--P2--d--PE2--e-CE2
My understanding is there is one 4 byte label for the MPLS VPN (MP-BGP label) plus one for MPLS transport (which is switched out by each P, then popped by PE2. If I want to deliver an edge MTU (at points a and e) of 1500 i expect to need a core MTU (at points b,c,e) of 1526 bytes (edge MTU 1500 + transport header (18 bytes for 802.1Q Vlan tagging) + 8 bytes for the 2 MPLS labels. I do have a core MTU (at points b,c,d) of 1526 but I'm only seeing and edge MTU of 1496. Can anyone confirm or deny whether 3 MPLS headers might be in use here? If only 2, where are my other 4 bytes going? Thanks!
-Chris
Solved! Go to Solution.
04-29-2008 08:26 AM
Hi Chris,
Actually the layer 2 header is 18 byte Ethernet header and Cyclic Redundancy Check (CRC) trailer, excluding the 4 bytes for the dot1q, and in this way you have your math done (1500 + 18 + 4 + 8).
BR,
Mohammed Mahmoud.
04-29-2008 08:26 AM
Hi Chris,
BR,
Mohammed Mahmoud.
