LMS 3.0
Answered Question
I installed lms 3.0 on a windows server (2003 R2 x64 bit standard edition).
I can connect via browser to the homepage. Homepage looks ok. Selftest is ok.
Report about process status is not possible. get an empty browser. Campus topology get an error message, Aniserver down. License report get an license server down message.
What services are mandatory on windows 2003 server.
Any hints about my problem?
HR
Correct Answer by Joe Clarke about 9 years 3 days ago
You need to upgrade to LMS 3.0.1 before you can get Windows 64-bit support. If ou have not already done this, you will need to uninstall LMS 3.0, and reinstall from scratch, then upgrade to 3.0.1 (you cannot use 3.0 on a 64-bit system). LMS 3.0.1 can be downloaded from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 .
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 04/29/2008 - 08:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
