Unable to establish IPSec LAN to LAN tunnel through a DSL line
Apr 29th, 2008
I have configured a 1710 to do all of the PPPoE stuff. I have set the DSL modem to "bridged" mode and I still have not been able to bring the tunnel up. Here is my config, please help!
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname CovingtonLA_1710
enable password cta
memory-size iomem 25
ip subnet-zero
ip dhcp excluded-address 10.10.173.1 10.10.173.49
ip dhcp excluded-address 10.10.173.61 10.10.173.254
ip dhcp pool Local_LAN
network 10.10.173.0 255.255.255.0
default-router 10.10.173.1
dns-server 10.2.2.10 205.152.132.23
lease 7
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
crypto isakmp policy 100
hash md5
authentication pre-share
group 2
crypto isakmp key XXXXXX address X.X.X.X
crypto ipsec transform-set TAStandard esp-des esp-md5-hmac
crypto map VPN 1 ipsec-isakmp
set peer X.X.X.X
set transform-set TAStandard
match address acl-crypto-blngmt
interface Ethernet0
no ip address
ip nat outside
half-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface FastEthernet0
ip address 10.10.173.1 255.255.255.0
ip nat inside
speed auto
interface Dialer1
mtu 1492
bandwidth 700
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username [email protected] password 0 XXXXXXX
crypto map VPN
line con 0
logging synchronous
line aux 0
line vty 0 4
password cta
login
end
william.caban Tue, 04/29/2008 - 20:12
Where is your "interesting" traffic? The traffic that you will encrypt. That must be defined by an ACL which is not defined (at least on this snapshot).
Take a look into the other part of "match address acl-crypto-blngmt". That should be defined.
At minimum, define the IPSec tunnel end points:
ip access-list extended acl-crypto-blngmt
permit ip host 10.10.173.1 host "remote-end-ip-addr"
HTH,
-W
/rate post if it helps
justinfvoeller Wed, 04/30/2008 - 08:15
I took out the ACL's, but they are required so here they are:
permit ip 10.10.173.0 0.0.0.255 10.10.186.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.2.2.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.4.186.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.10.190.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.10.188.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.4.188.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.10.183.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.4.183.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.10.184.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.4.184.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.10.180.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.4.180.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.10.181.0 0.0.0.255
permit ip 10.10.173.0 0.0.0.255 10.4.181.0 0.0.0.255
Richard Burts Wed, 04/30/2008 - 08:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Justin
I agreed with the previous post that the obvious fault in the original post was the lack of access list. If the access list was in the config and just omitted from the post then we need to look for some other issue.
This access list has a single subnet as the source and has 14 subnets as destinations. Is this correct? Are those 14 subnets reached through that remote peer?
Is the access list at the remote peer a mirror image of this access list?
Other possible problems to consider:
- is IP routing working? I do not see any route information in what you posted. Is this another thing that is in the config but that you omitted from the post?
- is the router establishing a working connection to outside resources? when the connection comes up is the router able to ping and traceroute to outside resources? Are PCs on the LAN able to browse to web servers in the Internet?
- do you have good IP connectivity with the remote peer? can the routers ping the VPN peer address?
- is the IPSec attempting to negotiate? Perhaps running debug crypto isakmp and posting the output would help us understand what is going on.
Rick
dwatson777 Thu, 05/01/2008 - 05:22
I'm pretty new at VPN as a backup and not familiar with the 1700 series but if you are trying to get a tunnel to open don't you need a tunnel interface? I don't see one in this config.
Richard Burts Thu, 05/01/2008 - 11:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Donnie
The terminology here gets a bit confusing. We talk about IPSec VPN as a tunneling technology because it takes an IP packet to be protected and encapsulates it in a new IP header, which is essentially what a GRE tunnel does. We frequently talk about IPSec tunnels as the way that the encapsulated traffic is sent. But IPSec does not require a tunnel interface. So this config does not need a tunnel interface.
Rick
