Cisco ICM integation with Avaya ACD
Answered Question
Apr 29th, 2008
Hi in our lab we integrating cisco ICM 7.2 with Avaya ACD S 8720 using AES server, in ciso Avaya PG is active, in Pg we can view avaya Agents status, if we are calling from avaya phones to one VDN is adjunt routed with Cisco PG,
call is hitting on cisco ICM , we are getting error message on abnormal rt_end in ECS_ PIM
Munirathnam
Correct Answer by ivillegas about 8 years 10 months ago
PIM receives the C_RT_END message from the MAPD and deletes the corresponding call information (SaoID). As the call is deleted from both the sides (PIM, MAPD), the TCP connection for that call no longer exists. If, in Post route scenario, PIM receives C_RT_END message before C_RT_SEL, it will throw this message of abnormal route end. Pim logs, with proper tracing will also show error related to this. Also you want to verify that you are not running out translation routes or have exhausted DNIS pool. These are the 2 scenarios that have been seen for this message.
http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a008014c68f.shtml
http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a008009492b.shtml
http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a00801a2d38.shtml#troubleshoot
Overall Rating: 5 (1 ratings)
Correct Answer
ivillegas Wed, 05/07/2008 - 12:11
  • Silver, 250 points or more
