Wireless connections always disassociate after every 30 minutes approximate
I have wireless setup consisting of WiSM and LAPs. Several WLANs are created, some with open authentication, some with web authentication and several with WPA/WPAs.
I discover that all wireless clients, regardless of which WLANs they are connected to, have their wireless connection drop after every 25-30 minutes, and they re-assiciated to their respective WLANs.
Have you guys encountered the similar symptoms?
d-berlinski Tue, 04/29/2008 - 09:53
Under WLAN Advanced settings is the session timeout which is by default 1800 seconds (30 min) after which a client must reauthenticate.
Scott Fella Wed, 04/30/2008 - 03:15
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You are correct... It will dissassociate the users when the timer expires.
Scott Fella Tue, 04/29/2008 - 09:54
  • Hall of Fame,
    2017 Wireless
Try to adjust your User Idle Timeout and see if that helps. Also make sure session timeout is not enabled on the wlan.
ericgarnel Wed, 04/30/2008 - 05:37
  • Gold, 750 points or more
Just out of curiosity, are you running a dynamic routing protocol on the underlying infrastructure?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
