Sessions Behind PIX
Apr 29th, 2008
I have 10 servers behind pix running multiple applications and clients are connected to them only when i allow there IP . But i want to manage a log file so every 1 passing PIX will be logged is there any way to do this. Is it possible using SYSLog
imranraheel Tue, 04/29/2008 - 11:58
basically one of the user is not been able to connect to a port , so i want to verify weather he is reachinging the server or is blocked on firewall
rkazmierczak Tue, 04/29/2008 - 12:35
for this kind of troubleshooting I would use either traffic capture on the PIX or even a sniffer (e.g. wireshark). You can SPAN the port on the switch and filter the traffic capture by ip address.
On the pix you can also use sh local-host command, but that info would guarantee that all is working OK.
imranraheel Tue, 04/29/2008 - 13:10
Is there any other why through which i can monitor the IP's. Using SYSlog etc
