MAC ACL doesn't work on 4507
Apr 29th, 2008
Greetings, all. I am attempting to spin a special QoS configuration in our 4507's for a non-Cisco IP phone, specifically the Aspect TeleSet3. They work well, but...
This phone has a PC port and does 802.1q tagging, but naturally does not use CDP, so the trusted boundary functions provided by "qos trust device cisco-phone" will not apply. The Aspect phones must coexist with Cisco phones on the same switch and VLAN, so I have decided to attack this at the port level.
My idea? By applying a policy map with a MAC ACL on the switch port, the MAC from the phone will be matched and its packets trusted, while MAC from the PC will not be matched, and its packets marked down to 0.
The problem? The MAC ACL doesn't match packets, even when the permit statement has a full host MAC address. Sniffer captures, "show policy-map", and "show access-list" confirm this. The service policy works, however, because all the packets are marked down to 0.
Here's a config extract:
mac access-list extended QOS-ASPECT
permit 0090.f300.0000 0000.00ff.ffff any
class-map match-any QOS-ASPECT
match access-group name QOS-ASPECT
policy-map QOS-ASPECT
description : ASPECT INPUT POLICY
class QOS-ASPECT
trust cos
class-default
set dscp default
policy-map QOS-ACCESS
description : ACCESS OUTPUT POLICY
class class-default
dbl
interface [slot/port]
description : ACCESS PORT
switchport mode access
switchport access vlan [data_VLAN]
switchport voice vlan [voice_VLAN]
qos trust cos
tx-queue 3
priority high
shape percent 33
service-policy output QOS-ACCESS
service-policy input QOS-ASPECT
Ideas? Call TAC? (ARGH).
Rick -Z-
tstanik Tue, 05/06/2008 - 05:36
  • Bronze, 100 points or more
You can filter non-IP traffic on a physical Layer 2 interface by using MAC addresses and named MAC extended ACLs. The procedure is similar to that of configuring other extended named ACLs. But, Named MAC extended ACLs cannot be applied to Layer 3 interfaces.For more information about the supported non-IP protocols in the mac access-list extended command, refer to the command reference for this release.
Refer the below URL for the ACL on 4500 series :
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/secure.html
