How Do You Release A DHCP Address on the Outside?
Answered Question
Apr 29th, 2008
How do you release the address on an ASA-5505 configured to grab an address from the ISP's DHCP server? I can't find a command anywhere, or anything in ASDM.
Correct Answer by srue about 9 years 1 month ago
under the outside vlan interface of the asa5505, you can assign a non-bia mac-address. assign it the same mac as your other router - if you know what that is. that way your ISP won't even realize you've been swapping gear on the line.
Overall Rating: 5 (1 ratings)
jsoudah Tue, 04/29/2008 - 14:35
No I didn't try that, but why would either one of those release an IP address? I'd be happy if it works though.
sundar.palaniappan Tue, 04/29/2008 - 15:29
  • Green, 3000 points or more
I don't know of a clear command to force the interface to release the DHCP learned address. Can you try the interface command 'no ip address dhcp' and to reenable dhcp 'ip address dhcp'.
Sundar
cisco24x7 Tue, 04/29/2008 - 18:12
  • Silver, 250 points or more
Very simple solution. I've tried with my Comcast cable modem provider and it works.
config t
interface e0
no ip address dhcp
shutdown
ip address 1.1.1.1 255.255.255.0
no shut
(wait for about 30 seconds)
no ip address
shut
(wait for 30 seconds)
no shut
ip address dhcp setroute
Now you will have a different IP address
jsoudah Wed, 04/30/2008 - 09:15
Thanks for the replies. I ended up trying something similar but it didn't break the lease on the ISP's DHCP server.
The reason I wanted to release it was because I was swapping devices back and forth for testing reasons, and if the address isn't released the other device won't get one. The other Verizon/Actiontec router has an address release option, so I just used that every time I wanted to break the lease and switch to the ASA. With the ASA it seems like you either have to ask the ISP to do it or just wait for the lease to expire.
Correct Answer
srue Wed, 04/30/2008 - 18:44
  • Blue, 1500 points or more
rextillojr Wed, 04/30/2008 - 21:35
Reenter this command to reset the DHCP lease and request a new lease:
ip address dhcp [setroute]
Note:
Make sure first that interface is enabled with the "no shutdown" command.
Rex Tillo
jsoudah Thu, 05/01/2008 - 10:00
Srue, good thinking don't know why I didn't think of that before.
rextillojr, I didn't want to renew the lease, just release it.
Thanks to eveyone for their help.
