how do you specify a string with advanced-balance url?
Apr 29th, 2008
I am trying to configure a CSS 11501 to send requests with a specific string in the URL to a specific server. How and where I would specify the string? The documentation, as far as I can tell, mentions that it can be done but does not show how. Any input is greatly appreciated.
Overall Rating: 4.5 (2 ratings)
Syed Iftekhar Ahmed Tue, 04/29/2008 - 16:14
  • Blue, 1500 points or more
service www1
ip address x.x.x.1
string Server1
active
service www1
ip address x.x.x.2
string Server2
active
content test
add service test
vip address z.z.z.z
protocol tcp
port 80
url "/*"
string prefix "goto="
string range 1 to 1000
string process-length 6
active
Syed
eleibowitz Wed, 04/30/2008 - 07:16
Syed, thanks for the quick response. If I understand this correctly, the CSS will look for the strings "Server1" or "Server2" in the URL, within 1000 bytes after "goto=". Is that correct? The documentation is not clear on the 'string process-length' command, so can you possibly explain that?
Thanks again,
Eliot
Syed Iftekhar Ahmed Wed, 04/30/2008 - 09:48
CSS will look for the server id within 1000 bytes (string range 1 to 1000 --- By defaukt CSS looks into first 100 bytes)
It will look for the string prefix (goto=) and then string process-length command is used to find the server ID after the prefix (how many bytes-- 6 in this case, after the end of prefix designated by the string prefix)
eleibowitz Thu, 05/01/2008 - 12:35
Thanks again, Syed. Now it makes sense, but I was digging more into the documentation and found a simpler way to accomplish this.
service webServer1
ip address 10.1.1.1
keepalive type http
active
service webServer2
ip address 10.1.1.2
keepalive type http
active
content webServers
add service webServer1
add service webServer2
balance aca
vip address 10.2.2.1
protocol tcp
active
content fileServer
protocol tcp
url “/files/*”
active
The idea being that most requests will get load-balanced between both web servers, but if the URL starts with "/files/", then only webServer1 will receive the requests.
