04-29-2008 02:58 PM - edited 03-13-2019 05:12 PM
Hi I have cisco 7970G connect to non cucm, the phone is on but dont receive any number, Would you help me?
05-06-2008 11:34 AM
Most likely your phone sip specfific configurations have been altered.What you have to do is to go to phone sip setting and configure it again. Alternatively, tftp again your SIP
Verify that your Register with Proxy set to yes and your proxy address is set.
11-21-2008 04:45 AM
Hi, I'm having this phone problem too (Unprovisioned). When you say 'go to phone sip setting and configure it again', do you mean by pressing the buttons on the phone, or by editing the sipdefault.cnf file? thanks for any pointers.
03-28-2018 11:04 AM
09-06-2023 11:23 PM
Hello Dear,
I took a super copy from the working IP phone 7841 and just changed the MAC address (Add New Phone MAC address) > save and also changed the extension number, The phone registered in cucm, the user(agent) uses all services but we cant record his/her's phone recording. In addtion, When I login the user(agent) with user-id & PIN it logged in into IP Phone 7841 but the phone becomes reset (unprovision, registration in progress) when I checked inside call manager (11.5) there it shows (unregistered), though the reset of same IP phone are working (userid logged in, can use all types of services). Could you please assist in this regard.
Thanks in advance,
