Allow user to change CFB, CFNA settings from Handset
Apr 29th, 2008
Is there a phone sevice that allows a user to change their own CFB or CFNA settings from the handset or authenticate and change other peoples.
Overall Rating: 5 (1 ratings)
rob.huffman Tue, 04/29/2008 - 19:37
Hi Heath,
There is a third party product called;
IPPhone callForwarder
This new version brings to the user the ability of defining and setting the call forwards from the IP Phone. When selecting the IP Phone callForwarder service, a menu with all available lines will appear. After selecting the line the user wishes to set the forward on, a new menu containing the forward definitions will show on screen. Only those forwarding parameters definied by the Administrator will be displayed. These parameters will show the actual forward destination. The user can then set any of these callForwards.
This tool allows users to set call forwarding from their IP phones. It's possible to set and clear the forwards for all the lines of the phone. It allows to set callForwardAll, callForwardNoAnswer, callForwardBusy and callForwardNoCoverage.
Hope this helps!
Jaime Valencia Wed, 04/30/2008 - 14:36
wow, i've never heard of that tool before, seems like something a lot of people could use
5 points for that great info Rob
rob.huffman Wed, 04/30/2008 - 14:54
Hi Jaime,
Thanks for your nice vote and kind words! This means a lot coming from you. This tool has been successfully used and is a good one for sure!
Take care,
