Switch authentication issue
Apr 29th, 2008
We are panning to migrate the user authentication method from Radius server to tacacs server for Cisco switches.
Can any one please help with the procedure or documents?
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 04/29/2008 - 23:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Start with this document and if you have further questions please come back.
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a0080094ea4.shtml
If you are migrating switches on remote sites make sure you start with a switch you can get physical access to just in case you manage to lock yourself out.
Jon
UCBNOCWAN Wed, 04/30/2008 - 00:16
Hi Jon,
Thanks very much for your help,the link is verymuch usefull for me.
yes i am doing the migration remotly, in this case i can take some local assistance for physical access to switch in case if i am locked out, could you please clarify
Jon Marshall Wed, 04/30/2008 - 00:23
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Once you have a working config then you should be fine remotely updating the switches. However when you are first testing this it is possible to lock yourself out of the switch/router so if you can test your config on a spare switch. if you don't have a spare switch test your config on a switch/router that is not critical in your environment.
Jon
