871 routers & 802.1x & WOL
Apr 30th, 2008
Hi all!
We are trying to use WoL on our different Cisco devices, which are controlled by 802.1x.
Thanks to the "dot1x control-direction in" command on each port, it works (Cisco 2960 switches for example) EXCEPT for 871 routers (the WoL frame doesn't wake up the computers). IOS release on these routers is 124-4.XC7
Any suggestion or comment as far as 802.1x & Wol are concerned? Did someone succeded in this case?
Thanks in advance
B
