Https timeouts with PIX 6.3?
Apr 30th, 2008
Does anyone have any experience of https timeouts when using PIX? I'm not completely sure what is causing the issue but when trying to access an https site from our internal LAN the session times out during the user authentication phase (i.e after having entered username and password).
The problem occurs when using the ISPs proxy server sitting on the network edge (which sends a timed out message) and when not using a proxy server. In both cases the traffic must traverse 2 PIXs running 6.3(5) before reaching the internet. The PIX timeouts looks high (1 hr default I think for TCP) but I cannot point to anything else as the cause for these https timeouts. When connecting from another private LAN or from my home broadband the https site loads ok and at a reasonable speed.
Any help much appreciated!
Paul
aghaznavi Tue, 05/06/2008 - 13:07
  • Silver, 250 points or more
Use the following command for setting the time parameters
ip http timeout-policy idle seconds life seconds requests value .
--Sets the characteristics that determine how long a connection to the HTTP server should remain open
