3750-G
drnteam
HI,
Can i delete the IOS directory from the 3750 switch, as im not able to upload the new version due to lcak of space.
Eldo
Mark Yeates
Level 7
Level 7
you can do a format flash: and it will remove your old IOS,. Or a better way to upgrade if you download the .tar IOS files. Here is an example
3750#archive download-sw /overwrite tftp://1.2.3.4/c3750-ipbasek9-mz.122-44.SE.bin
Hi Eldo,
As mentioned in the above post, you can definitely format the flash to erase the IOS and then upload the new IOS.
-> Sushil
