2 tacacs
Answered Question
Apr 30th, 2008
  • Silver, 250 points or more
hello
suppose i configured 2 aaa authentication login methods: one for dialup users and the second for telnet from network administrator:
aaa authentication login default group tacacs+ local
aaa authentication login whoisit group tacacs+ local enable
and suppose we will use 2 tacacs servers: one for each method.
is it possible to map each authentication method to one tacacs server?
i don't think so, because when defing the tacacs server there is no keyword to specify the aaa method.
any idea?
Correct Answer by mohammedmahmoud about 9 years 1 month ago
Hi Oussama,
Yes, you can use server-group:
aaa group server tacacs+ group1
server 1.1.1.1
aaa authentication login test1 group group1 local
tacacs-server host 1.1.1.1 key cisco
BR,
Mohammed Mahmoud.
Overall Rating: 4 (2 ratings)
Correct Answer
mohammedmahmoud Wed, 04/30/2008 - 03:17
  • Green, 3000 points or more
Hi Oussama,
server 1.1.1.1
BR,
Mohammed Mahmoud.
Richard Burts Wed, 04/30/2008 - 08:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Oussama
Mohammed is quite correct. I have done exactly what you are asking about to configure a router to support dial up users and to configure aaa authentication so that dial up users uathenticate with one TACACS server and the administrative (telnet) users authenticate with a different server. The ability to configure server groups makes this possible. And it works very well.
In my implementation I found it easier to let the dial users use the default authentication method (with one server group) and to specify a named method for the administrative users (with a different server group).
Rick
ohassairi Wed, 04/30/2008 - 21:19
hi rick
that's exactlly what i will do: dial users use the default authentication method and administrators use an other one.
thanks
ohassairi Wed, 04/30/2008 - 21:16
thanks mohammed. you have usually the solutions to my problems :-)
mohammedmahmoud Thu, 05/01/2008 - 03:52
Hi Oussama,
You are very welcomed :), and thank you for the rating.
BR,
Mohammed Mahmoud.
