Fully nonblocking architecture
Apr 30th, 2008
Hi all,
I have searching some specifications details, but i'm a litle unsecure about this, so here it goes:
I'm searching for the cheapest "Fully nonblocking architecture" LAN Switch.
What i mean for "Fully nonblocking architecture", is the summary throughput of all ports (UTP-1000), being equal or smaller than the backplane/bus of the switch, never "blocking/queueing", the traffic because the out of Bandwith.
Best Regards,
Bruno Petrónio
Jon Marshall Wed, 04/30/2008 - 03:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Bruno
How many ports do you need and do they all need to run at 1Gbps. The easiest way to find this information out is to go to LAN switches page and look at the data sheets for each which will give switch fabric details. As a general rule of thumb the bigger the number the more expensive ie.
a 6500 is more expensive than a 4500 which is more expensive than a 3750 etc.. although the 6500/4500 prices vary depending on which modules you need.
http://www.cisco.com/en/US/products/ps5718/Products_Sub_Category_Home.html
Jon
b.petronio Wed, 04/30/2008 - 05:00
Well,
Thanks for your quick response.
My client need at maximum a 8 utp ports, wich means a 12/24 ports switch is more than perfect.
The only issue is, that the client is sticked in the "nonblocking" feature word in the description characteristics.
Best Regards,
Bruno Petrónio
Joseph W. Doherty Wed, 04/30/2008 - 16:40
You didn't mention the number of ports you need nor whether you only needed L2.
Two "inexpensive" L2 switches that have gig ports, and enough forwarding rate (line speed) and backplane (32 gig) for their ports would be the 2960G-8TC-L and the 2960G-24TC-L.
See http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html for more information.
