04-30-2008 03:49 AM - edited 07-03-2021 03:47 PM
I have a new WLC and would like to upgrade the code on it. I looked on the downloads section on Cisco.com but could not find a release for the WLCM. Other modules yes, but not the WLCM. IS there a specific version I need for the WLCM or what hardware platform would be closet to the WLCM... 2106? Will any version of code work on the WLCM or does it stop at an older release?
Solved! Go to Solution.
04-30-2008 04:54 AM
Hi Bryan,
We do not run the WLCM but I do know that they require a special code. The various versions are downloadable (is that a word? :) via this search page. They are shown with a "lock" icon beside them;
For example;
Download Software for Cisco Wireless LAN Controller Module : AIR-WLCM-K9-4-2-61-0-ER.aes
Hope this helps!
Rob
04-30-2008 04:54 AM
Hi Bryan,
For example;
Hope this helps!
Rob
