RA VPN - Clients cannot connect
Apr 30th, 2008
Hey Folks,
In a lab, I've used the ASDM VPN wizard to apply the settings for a Remote Access VPN. The problem is that the clients cannot connect, they get this error:
713902 Group = RemoteVPN, IP = 192.168.3.2, Removing peer from peer table failed, no match!
713903 Group = RemoteVPN, IP = 192.168.3.2, Error: Unable to remove PeerTblEntry
Attached is a simple diagram of my lab network, and the config of my ASA 5505 firewall. Can anyone see where I've made my mistake?
SM
smahbub Wed, 05/07/2008 - 13:40
  • Silver, 250 points or more
The error message may be due to one of the following reasons:
1)The duplicate events are generated whenever a tunnel is torn down prematurely,
generally during the initial negotiation which causes.
2)Remote VPN peer may try to establish a VPN tunnel, the remote site may not have disabled the
VPN tunnel.Try disabling the vpn tunnel at the remote site.
singhsaju Fri, 09/19/2008 - 05:16
This could be due to ISAKMP policies of AES with SHA not supported on VPN client.
Try to make it work with minimum possible policies as suggested above like 3DES/SHA/Group2
Saju
