ip phones 7941 vs 7940
webstd.design
Can I use features from 7941 to 7940 phone? I want to use "list" of possible calling numbers that is used by 7941 phone.
Jaime Valencia
what do you mean by "list"??
are they going to be used with CUCM or CME?
javalenc
java
if this helps, please rate
As I know, 7941 can search numbers by enetering first some digits. Am I right?
that really depends on the directory search you have, not on the phone.
usually you get the option to type first name, last name or number, you don't need the whole thing but just one of those
javalenc
java
Javalen, I guess what he wants, is the autocomplete feature when dialing like the 7941 has. That is not available on the 7940.
