Mobility Manager Drops calls to remote destination over WAN
Apr 30th, 2008
I have the following setup:
Nortel Option 11 PBX --- E1 --- Cisco ISR --- WAN --- 2851 (H323) In UK -
-- CallManager --- Mobility Manager --- PSTN --- Deskphone/Mobile
Calls over the WAN to a Mobility Manager user in the UK
are failing. Call will ring on both deskphone and Mobile, if the user
picks up the call on the Mobile they get beeps and call disconnects.
Previously thought this was a codec issue but I configured the current
VoIP dial-peer on the VG in the UK to use only G711 and also set the
Regions between Remote site voice gateway and UK Users to use G711 also. Same
behaviour as before.
Any help or advice would be greatly appreciated
ivillegas Wed, 05/07/2008 - 12:41
There is a place for CTI host name, which is best to use the IP address of Callmanager. Have you tried deleting the CTI user and shared link from CMM and then re-adding them? Also make sure that the jtapi update is set to yes under system parameter. Then reset the CMM and see if they come in service.
This suggests a problem with the JTAPI version on MobilityManager.
Please double check the settings in MobilityManager per this document:
The settings should be:
Enable Auto Update JTAPI file set to YES
Always Update JTAPI File set to YES
Auto Update JTAPI Server Name or IP Address set to your CALLMANAGER ip address
Use Secured Auto JTAPI Update can remain at a default of NO
And, make sure that the following fields are EMPTY:
Auto Update JTAPI Server Path
Auto Update JTAPI Server File Name
Auto Update JTAPI Local File Name
