Unable to ping gateway from bridge but can ping bridge from gateway
Apr 30th, 2008
We have a wireless bridge connected to a router.
The the router whose f/e address 192.168.255.130 which is also the gateway of the bridge
The Bridges IP is 192.168.255.132
I am unable to telnet or even trace to that bridge from the gateway/router.
When I try and trace to it, I get sent out into our providers network
However I CAN ping !
router #ping 192.168.255.132
Sending 5, 100-byte ICMP Echos to 192.168.255.132, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/9/12 ms
ROUTER5#sh ip route 192.168.255.132 <-----BRIDGE IP
Routing entry for 192.168.255.132/30
Known via "bgp 65112", distance 20, metric 4
Tag 3561, type external
Redistributing via ospf 711
Advertised by ospf 711 subnets
Last update from 192.168.255.10 20:52:10 ago
Routing Descriptor Blocks:
* 192.168.255.10, from 192.168.255.10, 20:52:10 ago
Route metric is 4, traffic share count is 1
AS Hops 1
Route tag 3561
failed trace below
ROUTER #trace 192.168.255.132
Tracing the route to 192.168.255.132
1 192.168.255.10 4 msec 0 msec 0 msec
2 10.0.0.29 8 msec 0 msec 4 msec
3 10.133.14.20 8 msec
10.133.14.34 4 msec
10.133.14.20 4 msec
4 10.0.0.66 4 msec
10.0.0.62 12 msec
10.0.0.66 4 msec
5 192.168.255.37 [AS 3441] 12 msec
192.168.255.65 [AS 3441] 8 msec
192.168.255.37 [AS 3441] 8 msec
6 216.86.135.199 [AS 3441] 8 msec * 4 msec
7 *
192.168.255.138 [AS 3441] 8 msec *
8 192.168.255.134 [AS 3441] 24 msec * 24 msec
9 * * *
10 * * *
11 * * *
Now from the bridge....I fail to ping the gateway
102wireless#ping 192.168.255.130
Sending 5, 100-byte ICMP Echos to 192.168.255.130, timeout is 2 seconds:
Success rate is 0 percent (0/5)
router#sh ip int br
FastEthernet1/1 192.168.255.130 YES NVRAM up up
bridge#sh ip int br
BVI1 192.168.255.132 YES NVRAM up up
Does this make any sense?
lamav Wed, 04/30/2008 - 06:37
  • Blue, 1500 points or more
The bridge BVI and the f/e interface on your "router" are on the same subnet, right? Since you're calling the f/e the default gateway for the bridge, I imagine this is the case. A /24 mask maybe? Yes?
So what is "ROUTER5" and why do you get a /30 mask when you do a route lookup to the same address?
ROUTER5#sh ip route 192.168.255.132 <-----BRIDGE IP (Are you sure???)
You need to look into this and/or give us more information to help you out.
Victor
nygenxny123 Wed, 04/30/2008 - 06:59
yes..they should be in the same subnet
Bridge#sh run interface BVI1
Building configuration...
Current configuration : 83 bytes
interface BVI1
ip address 192.168.255.132 255.255.255.0
no ip route-cache
end
Router#interface FastEthernet1/1
ip address 192.168.255.130 255.255.255.248
no ip route-cache
ip ospf cost 7
ip ospf hello-interval 5
ip ospf dead-interval 30
duplex auto
speed auto
no cdp enable
end
However,
I have no problem logging into the client
end of the Bridge...Bridge B so to speak
The subnet masks are different on that and its gateway too
ROUTER B#sh running-config interface fastEthernet 0/1
Current configuration : 191 bytes
interface FastEthernet0/1
ip address 192.168.255.129 255.255.255.248
ip ospf cost 1851
load-interval 30
duplex auto
speed auto
end
BRIDGE B
BRIDGEB#interface BVI1
ip address 192.168.255.131 255.255.255.0
no ip route-cache
end
The masks for brige B and its gateway are different too.
And the only way i can telnet into bridge A
is to go through Bridge B (wireless)
I am pulling cdp from all devices
nygenxny123 Wed, 04/30/2008 - 07:36
here is what happens when i do a show ip route to the remote end bridge from the gatweay in question
router#sh ip route 192.168.255.131
Routing entry for 192.168.255.128/29
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via ospf 711, bgp 65xx2
Advertised by bgp 65xx2
* directly connected, via FastEthernet1/1
Route metric is 0, traffic share count is 1
