Problem with SDM software
Apr 30th, 2008
Hello, we are hav ing a trouble trying to find documentation for the following:
We have made a tunnel with the SDM software wich is connecting, but we want to keep the connection and the authentication to be automatic. We have to authenticate manually from the console each time we want to access. The SDM give us that option but if we configure it, it just does not works ! Do I need to do something extra to make te auth auto ? Thanks !!!
Istvan_Rabai Thu, 05/01/2008 - 06:28
Hi Xavier,
What kind of tunnel are you trying to create?
Could you please post the tunnel config commands on both sides of the tunnel from the output of the "show running-config" command?
Thank you:
