CSM url map and regexp - resource utilization
Apr 30th, 2008
hello all,
I need configure something like this:
policy STREAM-VOD
url-map STREAM-VOD
serverfarm STREAM-VOD
map STREAM-VOD url
match protocol http url */vod/*
my question is about url map definition: "*/vod/*". I can't define more specific regexp, because I don't know how many characters are before/after "/vod/". I need match any URL "/vod/" included. Any ideas?
example:
/servlet/create.sdp?clip=pv/p1/vod/free/umts_a3boot_A3_markiza_7sro_0804222358.21000101.3gp&ip=10.64.223.173&msisdn=421908367065
my question is about resource utilization, because (I thing) regexp '*something*' are very picky.. or I'm wrong?
thanks for help.
martin
Overall Rating: 4.5 (2 ratings)
Gilles Dufour Wed, 04/30/2008 - 06:57
  • Cisco Employee,
Martin,
there is no other solution if what you need is match the middle of a url.
The CSM will work fine with this map but you are limited in the amount of such maps that you can configure.
do a 'show mod csm X memory' to see the impact of the adding this map.
One is usually ok.
Two you will notice the memory increasing
Three the memory growth is exponential.
Gilles.
Martin Kyrc Wed, 04/30/2008 - 07:43
Gilles,
thank you for response. I need add this (one) url map to 2, or 3 policies. I will check memory usage.
It's possible to upgrade memory on the CSM module? from 250MB to more memory?
Gilles Dufour Thu, 05/01/2008 - 06:59
  • Cisco Employee,
There is no way to increase the memory.
Gilles.
