ACE 4710 MAC Address
Answered Question
Apr 30th, 2008
All physical interfaces on ACE 4710 share the same MAC address. Also, VIP addresses share the same MAC address. ACE 4710 is connected to a switch. How is the switch supposed to know which interface to send the packet to if it is doing layer2 switching.
Thank you in advance for the explanation.
Correct Answer by Syed Iftekhar Ahmed about 9 years 3 weeks ago
Answer is in your question.
Since all interface belong to different VLANs, all interfaces using same MAC doesnt matter.
For Incoming traffic Different Vlan Members will arp for diff addresses and will end up to ACE.
For outgoing traffic your routes will decide the outgoing ports.
Syed
Overall Rating: 4.5 (2 ratings)
Gilles Dufour Wed, 04/30/2008 - 08:08
  • Cisco Employee,
You can't put 2 interfaces in the same vlan
switch/Admin(config-if)# switchport access vlan 20
vlan 20 is associated with GigabitEthernet 1/3.
So, the L2 switch will have an entry for the mac-address in each vlan and this entry can point to different interfaces.
Gilles.
santipongv Wed, 04/30/2008 - 08:12
All three interfaces are in different VLAN. How will packet know which interface to send the packet to, though, since they all have the same MAC address.
Correct Answer
Syed Iftekhar Ahmed Wed, 04/30/2008 - 09:53
  • Blue, 1500 points or more
Syed
