04-30-2008 08:34 AM - edited 03-05-2019 10:42 PM
Are Jumbo Frames supported on the 2960 switch for Etherchannel links? I can't find anything in the documentation. I have found that the 3750 states that the MTU must be the same for the links to come up. I had jumbo frames working just fine until I setup an etherchannel between my blade switch and 2960 switch, and I was wondering if it is a limitation of the 2960.
04-30-2008 08:53 AM
Bill
Yes the 2960 supports jumbo frames - see attached link.
Jon
04-30-2008 09:46 AM
John,
Thanks for the quick response; however, I want to know if there is a specific limitation of Jumbo Frames in an LACP etherchannel. I know that the switch itself supports jumbo MTU as I have had this working until I changed the ports into an LACP link. If the switch is process switching the etherchannel packets (which I dont think it should be) that would limit the frames to the 1500 byte MTU limitation of the CPU which is the only thing I can think of.
04-30-2008 10:21 AM
Bill:
What do you have your Jumbo MTU size set for?
Im asking becuase the 2960 does not support CPU-bound packet sizes greater than 1998 bytes. CPU-bound traffic refers to control traffic, like SNMP, telnet, and I imagine PAgP protocol traffic.
Victor
04-30-2008 10:42 AM
System Jumbo MTU size is 9000 bytes
I would agree that the control traffic is limited, but I would think all the actual data-traffic is hardware switched.
More information: the etherchannel is between a HP GbE2c Ethernet Blade Switch, which according to their documentation supports Jumbo in etherchannel, so I am not quite sure where the problem is. The servers report they have Jumbo, so I think there must be something between the two switches.
