Jon Marshall Wed, 04/30/2008 - 09:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Major difference
RIPv1 is a classful routing protocol ie. the subnet mask is not transmitted with the routing update. So it does not understand VLSM.
RIPv2 is a classless protocol and does pass the subnet mask with the routing update and hence can support VLSM.
RIPv1 uses broadcasts for routing updates, RIPv2 uses multicast for routing updates.
RIPv2 suppports external route tags. RIPv1 does not.
Jon
Sushil Kumar Katre Wed, 04/30/2008 - 09:20
  • Gold, 750 points or more
Hi Naidu,
RIP v2 is an improved version of RIP v1 and *shares* the following features:
It is a distance vector protocol that uses a hop count metric.
It uses holddown timers to prevent routing loops - default is 180 seconds.
It uses split horizon to prevent routing loops.
It uses 16 hops as a metric for infinite distance.
RIP v2 *improved* features:
Transmit subnet mask with route
Provides authentication
Includes next hop route IP address in routing updates
Uses External Route Tags
RIPv1 -
Only Supports classful routing
No subnet info included in routing updates
Does not support VLSM
Broadcasts routing updates
RIPv2 -
Supports both classful and classless routing
Subnet info included in routing updates
Supports VLSM
Multicasts routing updates
-> Sushil
ilnaiduccna Wed, 04/30/2008 - 10:19
Hi Friends,
Thanks you so much both Jon and Sushil for their good help.
Naidu.
