CPU and Bandwidth utilization too high on Cisco 1721
mcyclegar
Hello All
I have having issues with High CPU and Bandwidth Utilization.
I am not a network specialist and hence need help.
I have attached show tech-support output.
I think the issue with some kind of attach.
I used SDM to configure the router.
Please help
Thanks in advance
Mcyclegar
Joseph W. Doherty
Alas, looks like your tech-support output missed one of the CPU spikes. If you could snag one when things are bad . . .
In the meantime, bold items might be removed/changed to reduce load:
interface Ethernet0
description $FW_OUTSIDE$$ETH-WAN$
ip address xx.xxx.42.169 255.255.255.224
ip access-group 101 in
ip verify unicast reverse-path <<== possible overkill
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect SDM_LOW out
ip route-cache flow
half-duplex <<== if supported, full or auto would be nice
no cdp enable
interface FastEthernet0
description $FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip nbar protocol-discovery <<== more possible overkill
ip route-cache flow
speed auto
no cdp enable
service-policy output SDM-QoS-Policy-1 <<== from 10 to 10 (or 100), shouldn't be any need
mcyclegar
Thanks for the reply joseph
I tried as you suggested and still i had problems , the cpu utilization was not going to 100% but was about 40-60 and bandwidth utilization was also like 30-30% and though internet was working fine i had issues with the VOIP phones on the network.
I tried disabling the firewall and its seems better now.
But this is not a good solution.
Can you please recommend me basic firewall setting which will not take the cpu load and also does not block the voice traffic.
Just a fyi VOIP required for my network to have 5060 to 6000 UDP ports open.
Can you please suggest me the configuration on that.
Thanks in advance
Mohammed
See reply.txt . . .
When you get the problem of bandwidth and high cpu I would suggest you to remote the NAT config and check if the problem is restored.
I have a feeling the NAT overload on this router model with crypto and other config would be causing the problem.
