Merge links
Apr 30th, 2008
Dear all
I have eight 2 Mbps link from Telco (g.shdsl) total sum = 16 Mbps
right now every 2Mbps is terminated on a G.shdsl modem,
I want to merge all the 2 Mbps togther..
according to number of links any idea please.
Paolo Bevilacqua Wed, 04/30/2008 - 12:56
  • Hall of Fame,
    Founding Member
Ask your telco if they are willing to do multilink PPP on the circuits. If so, you can purchase the G.shdsl cards for the router, and configure the MLPPP bundle.
If they cannot do that, you will just use 8 default routes, and there is no alternative to that.
