VG 248/Analog port Fast Busy
Apr 30th, 2008
Hi all,
I have an analog phone hooked upi to a VG248. As soon as I go off hook I get a fast busy.
The port is enabled and CCM 4.1.3 config is similar to working ports.
Any ideas,
Randall
Rob Huffman Wed, 04/30/2008 - 15:12
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Randall,
When you say the port is enabled did you telnet or console into the VG and enable it? (just curious) Is the corresponding Lamp on the front of the VG lit even before a phone is connected? If so the wiring from the RJ21 cable or cross-connect may have a short. This will give a permanent off-hook or "lockout" fast busy.
Let us know,
Rob
Jamil Hussain Mon, 05/21/2012 - 14:17
Hi Rob
I am facing the above issue,I configured the VG248 gateway and registered it with CUCM 4.1.3.
when i connected the fax i got fast busy signal i tested all the ports from 1-24  and 25 - 48.
Could you please tell me what might be the issue and how i can resolve it.
waiting for your reply.
thanks
