04-30-2008 12:13 PM - edited 03-15-2019 10:23 AM
getting the following error when calling a dn.
Cause i = 0x82E1 - Message type not implemented
Dialing phone to phone (4 digit) works fine. Any thoughts? Route Plan Report shows no overlapping
04-30-2008 12:22 PM
Are you pulling this from your gateway or trace logs from your CUCM? Can you be a bit more specific about the DN you are calling? Is this an internal or external call?
04-30-2008 12:31 PM
Pulling it from debug q931 off the gw. Actual number is external coming in through PRI. It originates as an inbound 800#, terminating on the 9200 DID
04-30-2008 12:47 PM
Does dialing the DID number work? Can you post the full debug?
04-30-2008 12:53 PM
Dialing the terminating DID number does not work. Here is the debug
*Apr 30 20:55:14.010: ISDN Se2/0:23 Q931: RX <- SETUP pd = 8 callref = 0x03EB
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2181, '6309558983'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '9200'
Plan:Unknown, Type:Unknown
*Apr 30 20:55:14.062: ISDN Se2/0:23 Q931: TX -> SETUP_ACK pd = 8 callref = 0x83EB
*Apr 30 20:55:14.090: ISDN Se2/0:23 Q931: RX <- STATUS pd = 8 callref = 0x03EB
Call State i = 0x06
*Apr 30 20:55:14.134: ISDN Se2/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x83EB
Cause i = 0x80E5 - Message not compatible with call state
*Apr 30 20:55:14.158: ISDN Se2/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x03EB
*Apr 30 20:55:14.202: ISDN Se2/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x83EB
04-30-2008 01:09 PM
Message not compatible with call state:
The remote equipment received an unexpected message that does not correspond to the current state of the connection. This is usually due to a D-channel error.
http://www.cisco.com/en/US/docs/ios/12_0/debug/command/reference/disdn.html
04-30-2008 01:11 PM
Are you sure you have the correct ISDN switch type configured? Since this sounds like a D channel error, perhaps the signaling is not compatible? Does the error occur just on this DID?
04-30-2008 01:13 PM
yes, all other did's and 800 inbounds work fine
04-30-2008 02:11 PM
do all the other numbers come in on thru the SAME PRI??
or do they use a different PRI??
javalenc
if this helps, please rate
05-01-2008 04:57 AM
Did you port these numbers from another carrier? Perhaps they didn't port this DID correctly? Is it a part of another DID block or is a single number?
11-09-2010 02:16 PM
I know this is an old Post, but I am having the same issue with the exact same setup mess
age you are getting, it is only happening on one DID, Telco is saying
Gateway is sending a Set_ACK instead of Call Proceding thus
they are sending back a "Message type not Implemented". Did you ever r
esolve this?
11-10-2010 07:55 AM
Looks like you have an overlapping dialplan on that number somewhere.
The Setup_Ack is sent if overlap receiving is enabled. For MGCP that is controlled with 'Overlap Receiving Flag for PRI' service parameter in CM, and is enabled by default. For H323/SIP, issue 'no isdn overlap-receiving' which is disabled by default. That will prevent the setup_ack from going out.
The error from the provider is a result of either your provider not supporting overlap sending, or perhaps you are configured for the wrong ISDN switch type.
