Cisco CUE AA Editor
Answered Question
Apr 30th, 2008
Im new on this, I install the AA Editor 2.3, I hit new, but after that, I can't drag and drop anything.
What is the problem?
thanks.
Correct Answer by mlitka about 8 years 12 months ago
Make sure you are dragging and dropping onto the 'Start' icon.
Overall Rating: 4.3 (3 ratings)
paolo bevilacqua Thu, 05/01/2008 - 08:13
  • Hall of Fame,
    Founding Member
Hi Rob,
I'm not 100% sure, but chances are that a newer CUE editor will produce files that are not usable on a previous version of CUE.
Personally, I've never found anything wrong with the 2.3.4 editor the few times that I've used it.
mlitka Thu, 05/01/2008 - 08:15
I can tell you from experience that it isn't backwards compatible.
Rafael Jimenez Thu, 05/01/2008 - 10:01
Hi, miltka, one question, if my CUE is 2.3.4 (UC500) my scripts should be done with AA Editor 2.3 , right?
mlitka Thu, 05/01/2008 - 10:17
Yes. I use 2.3 with my 2.3.4 install. The 3.x CUE Editors only seem to work with the 3.x CUE versions. I was looking for Release Notes earlier to back that up but couldn't find anything.
Correct Answer
mlitka Thu, 05/01/2008 - 06:35
Rafael Jimenez Thu, 05/01/2008 - 09:26
Incredible!!!, I did that exactly as you said, on the Start Icon, it works!!.
Thanks.
