NAC Host-Based Policies Issue
Apr 30th, 2008
I have a problem... when I try to permit in a temporary role a web page (for example www.microsoft.com) the user can't open it and display security message but when i add the web ip the users can access.... the nac is working on real-ip layer 3...
thanks for your help
Overall Rating: 1 (1 ratings)
cleidh_mor Thu, 05/01/2008 - 05:47
Have you allowed DNS traffic to a trusted DNS host?
Cheers,
asaldanab Thu, 05/01/2008 - 14:40
yes... i did it... :(
but its a default trusted dns policy... permit to all DNS Servers UDP port 53... is it correct? or i will type the IP address of my DNS manually?
cleidh_mor Fri, 05/02/2008 - 01:03
No that's fine, as long as that rule applies to the role of the PC.
Try an nslookup on the PC. What's the output?
>nslookup www.cisco.com
asaldanab Wed, 05/07/2008 - 07:40
hi...
in this moment im not in the company... the next friday i will try
thanks a lot!
ramkumar-b Wed, 05/07/2008 - 00:15
Are u using a proxy server in your network?
Try enabling Parse Proxy checkbox under
CCA Servers-->Filter--> Roles--> Allowed hosts.
Try putting proxy server IP address and port number under CCA Servers---> Advanced ---> Proxy
asaldanab Wed, 05/07/2008 - 07:42
hi
no... i dont have access to internet by proxy server... i have a firewall
the nac server is working in layer 3 real ip gateway... when i put the ip address of the page for example www.symantec.com the users can access... but when i permit the access by host .symantec.com in all options like ends, contain, etc can't access...
asaldanab Wed, 05/14/2008 - 09:37
The result of the dns lookup in the host is the next:
*** Can't find server name for address 172.16.48.253: Non-existent domain
*** Default servers are not available
Server: UnKnown
Address: 172.16.48.253
Non-authoritative answer:
Address: 74.52.164.242
Aliases: www.cisco.com.com.mx
The result of the nslookup in the CAS is the next
[[email protected]-MTY ~]# nslookup www.cisco.com
Server: 172.16.48.253
Address: 172.16.48.253#53
Address: 198.133.219.25
Help me
asaldanab Fri, 05/16/2008 - 14:56
Additionally, I'd like to say that my configuration is Out-of-Band Real-IP Gateway, Does anybody knows if there's a restriction to manage host-based policies?
gojericho0 Sun, 05/18/2008 - 05:10
  • Bronze, 100 points or more
Thats how mine was setup as well and it should not make a difference. What happens if you try to allow 'all traffic' in your policy. Does it resolve then?
cleidh_mor Mon, 05/19/2008 - 01:21
Additionally, could you post a screenshot of your traffic policy and the output from an ipconfig /all on the client?
