Cisco 3845 NM-1T3/E3 - Linecode b8zs option
Answered Question
Apr 30th, 2008
  • Green, 3000 points or more
We are geting ready to bring up a t3 circuit in couple of days, upon configuring t3 controller I do not
see linecode option to specify b8zs, the PE router I was told b8zs is the linecode to be used.
Would I need a different IOS code in order to have linecode parameter option available?
card type t3 4
controller T3 4/0
cablelength 25
interface Serial4/0
description MPLS_CIRID_
ip address xxx.xxx.xxx.xxx 255.255.255.252
dsu bandwidth 44210
EDGE3845_MPLS(config)#controller t3 4/0
EDGE3845_MPLS(config-controller)#?
Controller configuration commands:
bert Start BERT test at DS3
cablelength cable length in feet (0-450)
clock Specify the clock source for a T3 link
default Set a command to its defaults
description Controller specific description
exit Exit from controller configuration mode
framing Specify the type of Framing on a T3 link
help Description of the interactive help system
loopback Put the entire T3 line into loopback
mdl Maintenance Data Link Configuration
no Negate a command or set its defaults
shutdown Shut down a DS3 link (send DS3 Idle)
EDGE3845_MPLS#show controller t3
T3 4/0 is down.
Applique type is Subrate T3
Transmitter is sending remote alarm.
Receiver has loss of signal.
MDL transmission is disabled
FEAC code received: No code is being received
Framing is C-BIT Parity, Line Code is B3ZS, Clock Source is Internal
Data in current interval (60 seconds elapsed):
0 Line Code Violations, 0 P-bit Coding Violation
0 C-bit Coding Violation, 0 P-bit Err Secs
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs
60 Unavailable Secs, 0 Line Errored Secs
0 C-bit Errored Secs, 0 C-bit Severely Errored Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 P-bit Coding Violation,
0 C-bit Coding Violation, 0 P-bit Err Secs,
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs,
86400 Unavailable Secs, 0 Line Errored Secs,
EDGE3845_MPLS#
EDGE3845_MPLS#show ver
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(18), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 30-Nov-07 23:50 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
EDGE3845_MPLS uptime is 1 day, 11 hours, 31 minutes
System image file is "flash:c3845-adventerprisek9-mz.124-18.bin"
Cisco 3845 (revision 1.0) with 222208K/39936K bytes of memory.
Processor board ID FHK0904F11G
2 Gigabit Ethernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
1 Subrate T3/E3 port
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
Your comments are well appreciated
Rgds
Jorge
Correct Answer by mheusing about 9 years 1 month ago
B8ZS is used with T1 whereas a T3 will use B3ZS - as seen from the output of your "show" command.
Check f.e. http://en.wikipedia.org/wiki/B8ZS and http://en.wikipedia.org/wiki/B3ZS
So I am assuming a communication problem between your SP and you. Could you please double check with your provider, if he gave you the proper requirement?
Hope this helps! Please use the rating system.
Regards, Martin
Overall Rating: 5 (2 ratings)
Correct Answer
mheusing Thu, 05/01/2008 - 04:48
  • Cisco Employee,
Regards, Martin
JORGE RODRIGUEZ Thu, 05/01/2008 - 07:23
Thank you Martin !
You nailed it, and I've learned on T3 linecode. SP miscommunication.
Rgds
Jorge
