Cisco Ws-3550-24-EMI
May 1st, 2008
Dear XXXX
I bought a 3550 Switch of e-bay for my home lab, I have powered it up and if I issue a "sh IP int brief" command I only see one vlan interface an none of the fastathernet interfaces comes up.the IOs Image curreently is
c3550-i5q3l2-mz.121-13.EA1a. I want to know if the software image is corrupt or if the switch is damage. Can some one maybe give more in formation ?
I would be glad!
Jacob
Jon Marshall Thu, 05/01/2008 - 01:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jacob
If it is EMI you should be able to create multiple vlan interfaces on it ie.
int vlan 10
ip address 192.168.5.1 255.255.255.0
All new vlan interfaces will stay down until you allocate a port that is up into that vlan or you set up a trunk to another switch.
You may also need to issue the command "ip routing" on the 3550.
As for the fa interfaces. They will be down until you attach something into them.
Jon
jacob.botha Thu, 05/01/2008 - 01:38
Hi Jon,
Thanks for the qiuck reply,I know the fa/int will come up , but they don`t even show up in a "show run" command. There is nothing just 1 vlan interface, I can create mor vlan interfaces but thats about it.
!!! WARNING: The switch is not usable !!!
Press RETURN to get started!
00:00:23: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:24: %SCHED-2-WATCH: Attempt to set uninitialized watched boolean (address 0).
-Process= "VLAN Manager", ipl= 0, pid= 28
-Traceback= 1B67AC 2C4C08 35258C 34A2D4 3A6AEC 3AE308 3A9A84 3ACED8 3A99A0 3A4CD0 1C6440
00:00:24: %SYS-5-CONFIG_I: Configured from memory by console
00:00:25: %SYS-5-RESTART: System restarted --
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(13)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 25-Mar-03 23:42 by yenanh
00:00:26: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
00:00:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Switch>en
Switch#sh run
Building configuration...
Current configuration : 402 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
interface Port-channel1
no ip address
interface Vlan1
no ip address
shutdown
ip classless
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
jacob.botha Thu, 05/01/2008 - 01:52
Jon,
It looked like the internal power suplly has failed, cause the sytem light stays amber so I think that could be the problem,Would you know If I change the power supply with a 3500 xl could it effect anything?
Thanks for your help:-)
Jacob.
Jon Marshall Thu, 05/01/2008 - 02:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jacob
Apologies but i have never done that so wouldn't like to say for sure. Perhaps someone else can comment.
Jon
jacob.botha Thu, 05/01/2008 - 02:10
Jon
Thank for your help, I have done some crazy things with cisco devices and it sometines worked out so I will give it a go!
JAcob
