Hold Music on CM
May 1st, 2008
CM 4.2 - the hold scenario is "you are on hold...." plays 30 secs and loops
but sometimes the hold music does not play and leaves a blank space until it gets to "you are on hold........."
There is no pattern to this, sometimes the hold music will play - sometimes its blank
its the same wav file in the same place.....any ideas as to what may cause this, how to find out why or a solution
Many thanks
ebreniz Wed, 05/07/2008 - 13:47
The CM 3.1 feature (Music On Hold) does not currently work with ISN... Try this bug CSCma11233
I think you have 3 choices to do --
1. - limp along without MOH until after hours
2. - reboot subscriber
3. - re-order MRG to put a different MOH server first, and reset the device pool.
Jaime Valencia Wed, 05/07/2008 - 14:02
internal or external calls?
how many moh servers? co-resident or standalone? server model??
unicast or multicast?
how many concurrent calls can be on hold at the same time on your system?
there is a chance you're running out of moh streams.
if this helps, please rate
